Yomix
Yomix
<p>Ethereum is one of those mixing services that keep your crypto safe. The platform will take your bitcoin, mix it with other deposits, and give you the same amount of bitcoin in return. It’s designed to reduce bitcoin tracking, “clean” your coins, and help ensure anonymity on the transparent bitcoin network. A bitcoin mixer service like BitMix.Biz will take your bitcoin, then give you different bitcoin in return. The platform collects everyone’s bitcoin deposits, mixes them up into one central account, and then returns the bitcoins to users. You get the same amount of bitcoin (minus a fee), but different bitcoin from different parts of the blockchain. With BitMix.Biz, you get a letter of guarantee. That letter of guarantee is proof of BitMix.Biz’s obligations. When they give you their bitcoin address, they’ll provide a digitally-signed confirmation that this address has genuinely been generated by the server. That letter is always signed from the BitMix.Biz main bitcoin account (that account is publicly available on BitMix.Biz). The platform also uses a special 12 symbol “code” to ensure you get your bitcoin back every time you use the service. You save that code. That code also 100% excludes you from receiving your own coins anytime in the future. With Ethereum you will get: Fully Anonymity After your order is invalid, BitMix.Biz will remove any information about your transactions. Absolutely no logs or personality identifying information is kept regarding your use of the BitMix.Biz service. Instant Transfer Money is instantly transferred to your address after your transaction is confirmed. Partner Program Ethereum pays users when they refer others to the platform. They’ll pay for every transaction made by an invited user. The platform charges a mining fee of 0.4 to 4%. You can set the fee manually when you’re mixing your bitcoins. The address fee is 0.0005 BTC per output address to cover any transaction fees charged by miners. BitMix.Biz’s mixing process takes up to 24 hours, although it’s usually “almost instant” depending on the current service load. You’re required to mix a minimum of 0.007 BTC and a maximum of 1000 BTC. Transactions outside this range will not be accepted.</p><br><ul> <li><a href=https://yomix9.com/>Yomix</a> : Zero-log policy </li> <li>Bitcoin Laundry : Uses stealth pools to anonymize transactions </li> <li>Bitcoin Mixer : It offers flexible transaction fees and a low minimum transaction limit</li> <li>Mixero : Excellent customer support </li> <li>Coin Mixer : Fast payouts </li> </ul><br><br><h2 id=menu1>1. Yomix - Zero-log policy </h2><p>And last but not least, there is a coin mixer with a number of cryptocurrencies to tumbler named Yomix. At the moment, there are three currencies and Ethereum is going to be represented in future. This mixer offers a very simple user-interface, as well as the opportunity to have control over all steps of the mixing process. A user can select a delay not just by hours, but by the minute which is very useful. The tumbler gives the opportunity to use a calculator to understand the amount of money a user finally receives. The service fee is from 1 % to 5 % with fees for extra addresses (0.00045529 BTC, 0.01072904 LTC, and 0.00273174 BCH). Having funds from different resources helps the crypto mixer to keep user’s personal information undiscovered. This last mixer does not offer its users a Letter of Guarantee.Yomix supports Bitcoin and Litecoin cryptocurrencies bearing no logs policy. It requires a minimum deposit of 0.005 BTC, 0.015 LTC and the transaction fee is from 0.4% to 4% + mining fee 0.0003 for BTC, from 2% to 20% + mining fee 0.0003 for LTC. It supports multiple addresses of up to 5 and requires confirmation from 1 till 6. No registration is required and it does offer a referral program as well as a letter of guarantee.Yomix is yet another simple yet trustworthy Bitcoin Tumbler service. And one of the primary differences it has compared to the other platforms on this list is that it can accommodate really “large volume transactions”. Their claims to have Bitcoin reserves of over 2000BTC has been verified publicly (source: https://bitcointalk.org/generator.php?t ... sg15350012) so that also makes sure they won’t be running away with our Bitcoins and adds to their credibility. As for the mixing services, the receiving time is instant. Also, they’re pretty trusting and need only the following confirmations: <25BTC= 1 Confirmations. 25-250BTC=3 Confirmations. 250-1000BTC= 4 Confirmations. 1000+ BTC= 5 Confirmations. The receiving addresses have a validity of 24 hours, within which the payment has to be made. There is no Maximum transaction limit as such, considering how their reserve is really huge and you’ll need to be a millionaire before you can run them out of funds, and if any limit as such is involved, you’re notified during the process itself before you make the payments. The minimum transaction limit is 0.001BTC, anything lower than this is again considered donations like in the case of PriveCoin and isn’t sent out to the customer. As for the fee, their minimum fee is 0.5% (pretty low, huh?) with an additional 0.0005BTC for every deposited transaction. Although it varies for different amounts as the screenshot below explains: Also, it offers us additional control, by letting us control how much % of the Bitcoins will be sent in 1 transaction to one wallet address. Needless to mention, you can set a custom fee for added anonymity and they also provide a letter or guarantee like all the mentionable Bitcoin Tumblers out there.What marks Yomix out from the crowd is the fact that this crypto mixer is able to process transactions for Bitcoin and Litecoin. There is a minimum deposit requirement for both Bitcoin and Litecoin. The site is able to support a maximum of 5 multiple addresses with confirmation required for all addresses. No site registration is required and there is a referral program in place. Additionally, Yomix can provide clients with a letter of guarantee.</p><p> Pros: <ul><li>Uses stealth pools to anonymize transactions </li><li>User-controlled time delays</li></ul></p> <h2 id=menu2>2. Bitcoin Laundry - Uses stealth pools to anonymize transactions </h2><p>Straight off, Bitcoin Laundry is the only Bitcoin Tumbler we’ve ever crossed paths with which offers a “Free trial”! The free trial obviously doesn’t mean they’ll just send you free money; rather no fee or commission is charged for this free trial although it’s limited to, and is exclusive for 0.0001BTC tumbling only. Their process of acquiring the clean coins is quite unique, obtained from various stock exchanges such as DigiFinex, Cryptonex, Binance and so on; ensuring cleaner coins than some other questionable sources pertaining to their claimed check using a proprietary algorithm. In the background, a user’s money is first mixed in their pre-mixer with other coins; then sent to the stock exchanges for further mixing with other traders’ coins and then summoned back to be sent back to the users. The major flaw with the tumbler however is its lack of user-control, users have absolutely no control over the time-delays meaning you can’t specify the duration gap between the outputs rather it’s randomized between 1-6 hours. Distribution-control too can’t be controlled and the mixer sends randomized outputs to the addresses. The fee can’t be controlled by the users either and is again randomly set between 4-5%+ 0.00015 BTC network fee, truth be told it’s one of the highest tumbler fee we’ve ever seen. The minimum deposit limit is 0.0001 BTC and the maximum being 50BTC/ transaction.Compared to other Bitcoin tumblers, Bitcoin Laundry stands out from the crowd thanks to the additional anonymity offered. Users are given the option to split and merge coins into different wallets to various addresses. Additionally, Bitcoin Laundry provides support for unlimited addresses and does not require user registration. Although only Bitcoin is supported and there are no referral programs, ChipMixer does not charge users with any service fees. With the option to donate BTCs being made available.How it works: it has its own cryptocurrency reserve, which can be represented as a chain of bitcoins. When you transfer your funds to the Blender io, the resource sends your funds to the end of the chain and sends you new coins from the beginning of the chain that have nothing to do with the old coins. therefore, there can be no connection between incoming and outgoing coins. Only coins that go from your wallet to the Bitcoin Laundry address can be tracked through the public ledger, but no further. Blender io does not require you to register or provide any information other than the “receiving address“! It does not require identity confirmation and registration, but it is mandatory to provide in addition to the “receiving address”. The additional withdrawal delay feature has been extended to the maximum and offers installation up to 24 times a day. Other servers do not have such a wide range of latencies. Each set of unrefined coins can be split into as many as 8 pieces and sent to different addresses with an additional fee of 0.00008 BTC per address.Bitcoin Laundry runs on the Darknet and is one of the most popular Bitcoin toggle switches. This dark service uses new technology, it doesn’t just clean up your coins, you get brand new coins that have never been on the dark web. The cleaning process can take no more than 4 hours. To carry out cleaning on Helix in the basic version of Grams, you need to register, in the versions of Helix Light and Helix Market this is not necessary. If you still decide to use the Grams version, you will have to pay an entrance fee of 0.01 BTC. Helix has an additional feature (Auto-Helix) that allows you to specify which addresses your coins will be mixed with when they are credited to your account. Helix also enforces a “no log” policy, all logs are deleted automatically after 7 days or by the user immediately after completion of the output. Helix has a third party server not connected to Grams. A number of Bitcoin client programs that he uses are located on a completely separate server from Helix and Grams. Even if Grams is attacked or compromised, Helix will not be affected.</p><p> Pros: <ul><li>Available in Tor </li><li>Has impressive time delays</li></ul></p> <h2 id=menu3>3. Bitcoin Mixer - It offers flexible transaction fees and a low minimum transaction limit</h2><p>In the past, Bitcoin Mixer was one of the most popular Bitcoin mixers available in the cryptocurrency world. The first of its kind, this bitcoin mixer was shut down temporarily before returning to limited service. Nowadays, Bitcoin Mixer is primarily used to facilitate anonymous individual transactions.Bitcoin Mixer is a coin cleaning service that can hide your footprints in the cryptocurrency world. Currently, Bitcoin Mixer has a minimum withdrawal threshold of 0.03500000 BTC, so users are advised to transfer more than the entry threshold plus commission, otherwise they will not be able to withdraw funds. The client is given 5 exit addresses to be set. If for some reason, even after a delay of two hours, the user’s balance does not update, then the client can contact the support service to take action. For users who have been inactive for several days, it can take up to 15 minutes after logging in before you see outstanding deposits. The logs are kept for 7 days after which they are automatically deleted. The platform runs on a dedicated server that is openly connected via the Internet (you don’t need to do this when using the Tor browser). The Bitcoin mixer runs on a different machine, all suspicious activity is monitored and the website is automatically blocked on any signal that it is under intrusion.How it works: unlike other mixers, this site cleans coins with bitcoins purchased by them on cryptocurrency exchanges. Bitcoin Mixer io examines purchased coins using a scoring system with innovative algorithms and the use of technologies such as blockchain volume analysis, cluster analysis, pollution analysis, etc. After that, you will receive your BTC back, divided into random parts, and even sent in different addresses, if necessary. The whole process takes about 6 hours. The mixer does not require registration and does not store any logs. After each mixing operation, a letter of guarantee is sent, and information about it is eliminated after 24 hours, ensuring complete anonymity. The service also provides round-the-clock technical support. MixTum io charges a flat fee of 5% of the transaction, as well as a network fee of 0.00015 BTC. The program has two versions – for regular browsers and Tor.Grams itself is a brand on the Darknet so I believe not much needs to be said about it. Grams Helix is one of its subsidiaries and is one of the most reputed and widely used Bitcoin Mixer services out there, it’s simple, modern, and definitely trustworthy. Grams supports only Bitcoins for now. It needs 2 confirmations before it cleans and sends you your coins. It obviously supports time-delay, but it’s automatically set to “2 hours” for some reasons. It also supports “Random transactions” for the deposit, the deposit address changes after each transaction and allows you to send more than 1 transactions to Grams Helix instead of sending in all your coins in a single go. The same is also supported for the “output addresses” (where you receive coins) and you can input as many as 5 different BTC addresses where your coins are sent after cleaning them. The coin-deposit address is valid for 8 hours, and any transaction not done within these 8 hours won’t be received by the platform.</p><p> Pros: <ul><li>Allows extra payout addresses</li><li>It offers flexible transaction fees and a low minimum transaction limit</li></ul></p> <h2 id=menu4>4. Mixero - Excellent customer support </h2><p>Another solid Bitcoin Tumbler option, Mixero requires a minimum deposit of 0.01 BTC to be made but makes up for this with a lower transaction fee of 2% coupled with a 0.0004 BTC network fee. Support for multiple addresses and customer options is provided with users required to provide confirmation for only 1 address. While there is no referral program available, Mixero does offer users with a letter of guarantee for their peace of mind.Compared to other Bitcoin tumblers, Mixero stands out from the crowd thanks to the additional anonymity offered. Users are given the option to split and merge coins into different wallets to various addresses. Additionally, Mixero provides support for unlimited addresses and does not require user registration. Although only Bitcoin is supported and there are no referral programs, ChipMixer does not charge users with any service fees. With the option to donate BTCs being made available.Mixero makes the process of clearing bitcoins very easy and convenient for the client. This resource requires one confirmation of the transaction, after which new clean coins are sent to the specified wallet. Users can also control latency for processing their transactions. This is an offshore service, and its sites are also located offshore. This provides users with additional peace of mind and confidence that their data is strictly confidential. In addition, once the transaction is confirmed, users are sent a unique “delete logs” link, giving users the ability to manually delete their traces of transactions. Mixero charges a modest 0.5% commission. This makes BTC Blender ideal for users clearing large amounts of bitcoin.As well as others, Mixero has both a clear-web CryptoMixer. This mixing service is notable for accommodating extremely large-volume transactions. After public verification of their reserve of 2000 BTC there is no doubt that users can trust this mixing service and their cryprocurrencies will not be taken. The number of needed confirmations differs depending on the deposited amount, e.g. for depositing less that 25 BTC there is only 1 confirmation needed, in case of sending more than 1000 BTC a user needs to gather 5 confirmations. To use this platform, a Mixero code needs to be created. A user should note it, so it is easy to use it next time. After entering a CryptoMixer code, users need to provide the output address or several of them and then set a time-delay feature. A delay time is determined automatically and a user can modify it if needed. A service fee can be also selected from the table depending on the sent sum. Each transaction requires additional fee of 0.0005 BTC. Also, a calculator on the main page helps every user to see the amount of crypto money sent and got back after mixing.</p><p> Pros: <ul><li>It offers flexible transaction fees and a low minimum transaction limit</li><li>It has a positive reputation among the Bitcoin community</li></ul></p> <h2 id=menu5>5. Coin Mixer - Fast payouts </h2><p>Coin Mixer will be reliable and easy to use. It has been around for several years and is probably considered one of the most popular mixers on the darknet. Coin Mixer charges a commission randomly in 1-3%, and also provides sending coins to 10 different addresses for increased anonymity. Due to randomization, withdrawal amounts turn out to be unpredictable, which again increases anonymity. BitBlender requires you to create an account to use the full suite of tools, but if you don’t want to register, this mixer offers a “quick blend” mode. When using the Quick Mix feature, you will be sent a code that identifies each individual operation to ensure that you do not receive any previously sent coins back. BitBlender provides two additional features. Auto-Withdrawal and Quick-Withdraw. Auto-Withdrawal will dramatically decrease your runtime if you have to constantly clean your coins. Quick Mix comes in handy for the casual user who doesn’t want to register.Coin Mixer is a Bitcoin mixing service that provides privacy by using the ‘Bitcoin Mixer 2.0’ algorithm to shuffle bitcoins. Unlike other similar tumbling services that mix your coins with the coins of other users, this platform mixes your crypto with the crypto bought by them directly from the cryptocurrency stock exchanges. Coin Mixer verifies the newly purchased coins with a scoring system with the help of innovative algorithms and outfoxes such technologies as blockchain volume analysis, cluster analysis, taint analysis, etc. It means that you will receive your BTC back split into random parts, and even at the different addresses if needed. Consequently, your privacy is protected as there is no connection to you. And it takes up to 6 hours to complete your request. Another privacy feature of this mixer service is that it does not require registration and it does not store logs. All the transactions are digitally signed with letters of guarantee that you can check on the website at any moment. They also provide 24/7 technical support. MixTum.io will charge you a 5% Fee from your transaction as well as a network fee of 0.00015 BTC. The platform provides two versions – for Clearnet and Tor browsers.Coin Mixer is a btc shuffle service needed to hide your transfers in the bitcoin world. Coin Mixer currently has a minimum withdrawal threshold of 0.03500000 BTC, so users are advised to deposit more than the entry threshold plus commission, otherwise they will not be able to withdraw funds. The client is asked to set 5 exit addresses. If for some reason, even after a delay of two hours, the user’s balance is not updated, the mixer can contact the support service to take action. For customers who have been inactive for several days, it can take up to 15 minutes after logging in before you see outstanding deposits. Transaction histories are automatically deleted within 1 week after that. The program runs on a dedicated server that is openly connected via the Internet (you don’t need to do this when using the Tor browser). The Bitcoin mixer is launched on another machine, all suspicious activity is monitored, and the website is automatically protected in case of any indication that it is under DDoS attack.One of the most currency-rich mixers in the industry, letting us Mix not just Bitcoin but Litecoin, Bitcoin Cash and Ethereum (coming soon) is what Coin Mixer is. Also flaunts probably the most colourful and easy to use Interfaces I’ve ever seen. Provides 100% Control to users regarding every aspect of the mix. As in, users control the exact amount of fee (to the 4th decimal point!), the exact time-delay (by the minute and not just hours) and also the Percentage distribution. It’s transparent and even has a “fee calculator” which displays the exact amount of funds a user would receive on each additional address, as well as the total service and the address-fee. Maximum 8 total output addresses allowed. The minimum service fee a user can pay is 1%, with the maximum being 5%. The additional address fee is 0.00045529 BTC, 0.01072904 LTC, and 0.00273174 BCH for Bitcoin, Litecoin and Bitcoin Cash respectively. Has three fund-pools, and they all have funds from different sources in them which have different levels of anonymity. Does have a “No Logs Policy”. No registration required.</p><p> Pros: <ul><li>24/7 customer support </li><li>Offers a low minimum deposit of 0.002 BTC </li></ul></p>
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 36 gości
