Yomix
ErnestCon
Yomix
Post autor: ErnestCon » 30 kwietnia 2025, 15:50
<p>Bitcoin blender is a Bitcoin mixer that processes Bitcoin and Bitcoin Cash transactions. The site offers a referral program for new users and supports multiple recipient addresses. Transaction fees start at 0.5% plus an extra 0.0001 BTC for each extra address added.</p><br><ul> <li><a href=https://yomix9.com/>Yomix</a> : Zero-log policy </li> <li>Bitcoin Mixer : It offers flexible transaction fees and a low minimum transaction limit</li> <li>Bitcoin Laundry : Uses stealth pools to anonymize transactions </li> <li>Coin Mixer : Fast payouts </li> <li>Mixero : Excellent customer support </li> </ul><br><br><h2 id=menu1>1. Yomix - Zero-log policy </h2><p>Yomix only supports Bitcoin transactions and requires customers to deposit a minimum of 0.001 BTC. Transaction fees range from 0.5 to 3% depending on the amount that is being transferred. This Bitcoin mixer supports multiple addresses and custom options (max of 10). Nonetheless, confirmation is required. Yomix does not have a referral program in place.One of the most currency-rich mixers in the industry, letting us Mix not just Bitcoin but Litecoin, Bitcoin Cash and Ethereum (coming soon) is what Yomix is. Also flaunts probably the most colourful and easy to use Interfaces I’ve ever seen. Provides 100% Control to users regarding every aspect of the mix. As in, users control the exact amount of fee (to the 4th decimal point!), the exact time-delay (by the minute and not just hours) and also the Percentage distribution. It’s transparent and even has a “fee calculator” which displays the exact amount of funds a user would receive on each additional address, as well as the total service and the address-fee. Maximum 8 total output addresses allowed. The minimum service fee a user can pay is 1%, with the maximum being 5%. The additional address fee is 0.00045529 BTC, 0.01072904 LTC, and 0.00273174 BCH for Bitcoin, Litecoin and Bitcoin Cash respectively. Has three fund-pools, and they all have funds from different sources in them which have different levels of anonymity. Does have a “No Logs Policy”. No registration required.Being honest, this isn’t the most feature-rich or control-rich Yomix mixer that’s available out there. However, it still averages mixes over 700Bitcoin/day (claimed, not verified). The coins are claimed to be sourced from mining pools in the U.S, China and Europe. Obviously they do not keep any logs. Unfortunately, only 1 output address is allowed which is a bit of a downer. The time-delay can fully be set manually. It can be as low as 0 hours, or as high as 48 hours. Any other delay between this frame can be set using the provided slider. The fee isn’t randomized, neither is it user-controlled. It’s set at a solid 0.1% for all transactions. Accepts a minimum Bitcoin deposit of 0.010BTC. Maximum funds which can be currently mixed stand at 677 BTC. Number of required confirmations depend on the amount. Only 1 is required for mixes below 2.5BTC. For 25 BTC it needs 3 confirmations. 4 confirmations for 40BTC and 5 confirmations for 50 BTC are required respectively. Doesn’t require registrations.Yomix is a coin cleaning service that can hide your footprints in the cryptocurrency world. Currently, Yomix has a minimum withdrawal threshold of 0.03500000 BTC, so users are advised to transfer more than the entry threshold plus commission, otherwise they will not be able to withdraw funds. The client is given 5 exit addresses to be set. If for some reason, even after a delay of two hours, the user’s balance does not update, then the client can contact the support service to take action. For users who have been inactive for several days, it can take up to 15 minutes after logging in before you see outstanding deposits. The logs are kept for 7 days after which they are automatically deleted. The platform runs on a dedicated server that is openly connected via the Internet (you don’t need to do this when using the Tor browser). The Bitcoin mixer runs on a different machine, all suspicious activity is monitored and the website is automatically blocked on any signal that it is under intrusion.</p><p> Pros: <ul><li>Has impressive time delays</li><li>Excellent customer support </li></ul></p> <h2 id=menu2>2. Bitcoin Mixer - It offers flexible transaction fees and a low minimum transaction limit</h2><p>It is a simple service with a high level of anonymity. The Bitcoin Mixer mixing process is very simple and only takes a couple of minutes. You need to select one of the three supported cryptocurrencies (Bitcoin, Litecoin, Bitcoin Cash), enter the withdrawal address, set the transaction delay for any time up to 72 hours, send the coins to the specified address and wait for their delivery to the destination. This site is unlike the other three mixing pools. You can mix user’s coins: with incoming coins of other customers, private reserves of the service and investor coins. The service does not require registration. The mixing commission is not large and is taken from the mining commission, which is very convenient. The referral program at SmartMixer is one of the most profitable, during the first mixing operation you receive a smart code that is required to receive a discount on the commission, this discount can reach – 70%. After each transaction, the user receives a letter of guarantee. All data about it is deleted after a day, while maintaining the complete anonymity of the client.Bitcoin Mixer is a Bitcoin mixer that processes Bitcoin and Bitcoin Cash transactions. The site offers a referral program for new users and supports multiple recipient addresses. Transaction fees start at 0.5% plus an extra 0.0001 BTC for each extra address added.Bitcoin Mixer is a very impressive service if you want to maintain your anonymity when you make purchases online. It can also be useful if you want to do p2p payments and donations. The service is used to mix a person’s funds and give this person some fresh bitcoins. The focus here is on making sure that the blender has the ability to confuse the trail as somebody could try to figure out the source. The best mixer is that one that keeps your anonymity at a max. You want each bitcoin transaction to be very hard to trace. This is where using our bitcoin mixing service makes a lot of sense. Protect your income and personal information becomes much easier. The reason why you want to use our service is because you want to hide your coins from hackers and third-parties. They can do a blockchain analysis, they may be able to track your personal data to steal your bitcoins. With our bitcoin tumbler, you don’t have to worry about that anymore.An interesting cryptocurrency tumbler is Bitcoin Mixer. It supports bitcoin and Ethereum cryptocurrencies bearing no logs policy. It requires a minimum deposit of 0.2 BTC and the transaction fee is 2–5%. It does not support multiple addresses and requires 6 confirmations. No registration is required and it does not offer a referral program.</p><p> Pros: <ul><li>User-controlled time delays</li><li>Extensive FAQ section </li></ul></p> <h2 id=menu3>3. Bitcoin Laundry - Uses stealth pools to anonymize transactions </h2><p>Bitcoin Laundry bitcoin mixer is one of the few that allows large-volume transactions. The minimum size for a mixing operation is 0.001 BTC, any amount below this level is considered a donation and is not sent back to the client, there is no maximum transfer limit. The minimum commission is 0.5% with an additional fee of 0.0005 BTC for each incoming transaction. During the transaction, you will receive a letter of guarantee, as in all previously mentioned mixers.Bitcoin Laundry has a simple interface, it is easy to use and simple. Time-delay option can be set up to 24 hours. With regard to the fee, there is an additional fee of 0.0005 % per output address. As one of the few, this cryptocurrency tumbler provides a user with a special mixing code which guarantees that fresh crypto coins are not blended with previous deposits. Additional URL Blender is also here to guarantee that users can get to the tumbler, even if the main link is not working.Bitcoin Laundry provides all the anonymity and protection that comes standard with a Bitcoin mixer, as well as many optional features and benefits that you won’t find anywhere else. If you use a new address for withdrawal, the coins you receive back are completely separated from your previous history on the blockchain, so it is almost impossible to link the transaction history with your personality. SmartMix commission is only 0.5% of the deposit amount plus 0.0001 BTC / 0.00005 BCH for each exit address. 5 output addresses can be set. The privacy policy makes it possible to delete all mixing information as soon as it is completed. The resource provides fast and reliable mixing of bitcoins through a simple and attractive user interface. Bitcoin Laundry has made two additional functions for its clients in contrast to its colleagues: 1. Affiliate program. Share your anonymous referral link and earn cryptocurrency bonuses. For each mixing operation performed on your link, you receive 50% of the service fee. 2. Loyalty reward program. Use your anonymous SmartClub code with every mixing operation to receive service charge discounts. The more you mix, the more you save.Supporting multiple types of cryptocurrency, Bitcoin Laundry is one of the most flexible Bitcoin tumblers available today. Besides requiring a minimum deposit, service fees are charged, and users are required to register to use this site. Referral programs are also on offer along with support for multiple recipient addresses (max 10).</p><p> Pros: <ul><li>Provides user-controlled time delays </li><li>Proven track record</li></ul></p> <h2 id=menu4>4. Coin Mixer - Fast payouts </h2><p>Based on the experience of many users on the Internet, Coin Mixer is one of the leading Bitcoin tumblers that has ever appeared. This scrambler supports not only Bitcoins, but also other above-mentioned cryptocurrencies. Exactly this platform allows a user to exchange the coins, in other words to send one type of coins and get them back in another type of coins. This process even increases user’s anonymity. Time-delay feature helps to make a transaction untraceable, as it can be set up to 24 hours. There is a transaction fee of 0.0005 for each extra address.It is a simple service with a high level of anonymity. The Coin Mixer mixing process is very simple and only takes a couple of minutes. You need to select one of the three supported cryptocurrencies (Bitcoin, Litecoin, Bitcoin Cash), enter the withdrawal address, set the transaction delay for any time up to 72 hours, send the coins to the specified address and wait for their delivery to the destination. This site is unlike the other three mixing pools. You can mix user’s coins: with incoming coins of other customers, private reserves of the service and investor coins. The service does not require registration. The mixing commission is not large and is taken from the mining commission, which is very convenient. The referral program at SmartMixer is one of the most profitable, during the first mixing operation you receive a smart code that is required to receive a discount on the commission, this discount can reach – 70%. After each transaction, the user receives a letter of guarantee. All data about it is deleted after a day, while maintaining the complete anonymity of the client.Coin Mixer is one of the most pocket-friendly, easy to use and customizable Bitcoin laundry platforms in the industry. The user-interface is extremely simple and clean, anyone who has never before used any such service too can navigate around and tumble Bitcoins easily. No registration is required to mix Bitcoins on Blender.io Its “delay” feature lets you set delays from 1-24 hours which increases your anonymity by providing a gap between the deposited coins and the outgoing ones. As for the fee, it’s dynamic, meaning you get to choose the amount of fee you’d like to pay, the minimum fee being 0.5% and the maximum being 2.5% with an additional 0.0005%/address. It’s also one of the rare platforms which provides you with a mixing code which makes sure your previous coins do not get mixed with your newer deposits if you do multiple deposits to the tumbler. The minimum amount you can mix is 0.001BTC while there’s no specific maximum amount as their Bitcoin reserve seems to be quite large. It also has a No Logs Policy and all data is instantly deleted as soon as a transaction is complete; and as for the number of confirmations required it’s 3 for your deposit to be mixed by Coin Mixer It supports 8 addresses for each mix so you can further increase your anonymity. In a nutshell, it gives you the power to choose, is fast, anonymous and totally worth a try. It also supports Segwit and bech32 Addresses, with some terms attached. For e.g. only witness version bech32 addresses are supported. Similarly, only the addresses starting with the number “3” are supported.Coin Mixer is another one that requires consideration. It supports Bitcoin cryptocurrency bearing no logs policy. It requires a minimum deposit of 0.001 BTC and the transaction fee is 4–5%. It supports multiple addresses of 2 or custom options and requires confirmation. No registration is required and it does not offer a referral program. Letter of guarantee is offered.</p><p> Pros: <ul><li>Offers a low minimum deposit of 0.002 BTC </li><li>Uses stealth pools to anonymize transactions </li></ul></p> <h2 id=menu5>5. Mixero - Excellent customer support </h2><p>This Mixero also supports Bitcoin and other cryptocurrencies like Ethereum, Bitcoin Cash, and Litecoin bearing no logs policy. It requires a minimum deposit of 0.005 BTC, 0.01 BCH, 0.1 ETH, 1 LTC, and the transaction fee is 0.5% plus 0.0005 for each extra address. It supports multiple addresses of up to 10 and requires confirmation from 1 to 50. No registration is required and it does offer a referral program. Also, it comes with a letter of guarantee.Mixing Bitcoins is made simpler with Mixero. A mixer available both on the Clearnet and the Tor network. Offers complete control over the time-delays and fund-distribution. Charges a static fee of 0.3%. Maximum number of output addresses allowed is 10. Each address is charged an additional 0.0001BTC. Largest possible mix is 100 BTC, while smallest accepted deposit is 0.002 BTC. No registration required. Has a No Logs Policy, retains logs for 7-days by default. Although users can delete logs anytime before the 7-day period manually. Does provide Certificate of Origin. Also has an “Instant Dispatch” feature of delivering coins without any delay.Mixero is a btc shuffle service needed to hide your transfers in the bitcoin world. Mixero currently has a minimum withdrawal threshold of 0.03500000 BTC, so users are advised to deposit more than the entry threshold plus commission, otherwise they will not be able to withdraw funds. The client is asked to set 5 exit addresses. If for some reason, even after a delay of two hours, the user’s balance is not updated, the mixer can contact the support service to take action. For customers who have been inactive for several days, it can take up to 15 minutes after logging in before you see outstanding deposits. Transaction histories are automatically deleted within 1 week after that. The program runs on a dedicated server that is openly connected via the Internet (you don’t need to do this when using the Tor browser). The Bitcoin mixer is launched on another machine, all suspicious activity is monitored, and the website is automatically protected in case of any indication that it is under DDoS attack.Based on the experience of many users on the Internet, Mixero is one of the leading Bitcoin tumblers that has ever appeared. This scrambler supports not only Bitcoins, but also other above-mentioned cryptocurrencies. Exactly this platform allows a user to exchange the coins, in other words to send one type of coins and get them back in another type of coins. This process even increases user’s anonymity. Time-delay feature helps to make a transaction untraceable, as it can be set up to 24 hours. There is a transaction fee of 0.0005 for each extra address.</p><p> Pros: <ul><li>It has a positive reputation among the Bitcoin community</li><li>Zero-logs of your transactions </li></ul></p>
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 18 gości
